Hello
quakzopas
Germany
Hello @everyone,
I'm Max from Germany and about to buy my first drone šŸ˜€
I cannot decide which one to take and actual I'm
collecting all information I can get.
I choose between the DJI mini 4 pro, Avata 2 (because of the fun 😁), air 3 and mavic 3 classic.
The purpose is make "the most" good quality videos and picture for the less money?!
And I'm thinking about using the FCC mode in some areas šŸ˜‡
Greetings
Max
I highly recommend the DJI Air 3 for the best all-around images and video and the money. If you have a higher budget, consider the Mavic 3 Pro. If you're into FPV then the Avanta 2 is the way to go
Hello from the Crossroads of America quakzopas.
Nice to meet you Max. :cool:
GFields has good advice above.
... about to buy my first drone šŸ˜€
I cannot decide which one to take...
Purchase all of them. šŸ˜€
Saves that decision making process.
Welcome to the Forum. :cool:
All the drones you list take good to great photos and videos, but the Avarta is FPV and in a class by itself. Basic rule with all of these drones is spend more, get more… but you gave a simple statement of purpose, "The purpose is make "the most" good quality videos and picture for the less money?!" So the answer is the DJI Mini 4!
Still undecided, watch lots of YouTube Videos!!!
Since you live in Germany, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Hi from Ireland, seen the Air 3 on youtube videos, the camera looks superb for both pictures and video, as someone said earlier you pay for what you get, good luck and happy flying.
Most important to me.
Whats your experience flying a bird in the air with a remote?
Good day can go bad really fast.
Been there. :rolleyes:
Almost forgot.
Welcome to the Forum!! šŸ‘Œ
Rod ..
Welcome to the forum from the beautiful woods of Maine USA!
I vote for the Air 3, it has everything you need at a good price.
Reactions: LoudThunder
TPS
