- Joined
- May 27, 2017
- Messages
- 992
- Reactions
- 1,272
You can see it better here:took a screen shot could you please confirm which direction it was going.?
Yes! I have some questions about why you were running 25 minutes on your batteries but glad you found your bird.
Please ...Go ahead and ask
But before you ask..... Did you see the flight log.?
Yes but I am still learning to decipher. What are you flying? It looks like you went up up up between 23 and 24 minutes until you reached 477' and then went down down down because the battery was so low. Were you getting no warnings? Also is that battery dead? It kept having different cells highlighted through your flight.
Glad you got it back, I thought it was goign to be high up in a tree.
Thank JDawg
.......I fly a Mavic Pro 1 for 20months ( 05-26-17)
have almost 24Hrs total of Flight on My Mavic
I have a hard and fast Rule never fly with less then 20% battery .!
Why was i flying at 25 Minute.?
I was close and wanted to see if I could get a Low battery warning and see if it would
RTH @18 battery
Flying up a hill and with trees wanted to keep in LOS
My RTH is set @ 18% battery
also RTH with Loss of signal with controller.!
During this Flight a recieved several "Craft disconected from controller" and recovered
@ 23 Minutes My battery meter showed 75% I passed by my home port 700ft away
@24 minutes my battery dropped to 28%
@24..... got a "Disconected"(loss of satilite signal)
had no control you can see on the map a Triangle Thats when i tried to recall Mavic
but it would not...
the log shows I had hard full up on my right handle (Comand to climb) @479ft
@24.40 The battery shows 22% and Manual landing
@25 minutes lost satalite signal
I can't find in the log
the several times when recieved
"Disconect with controller"
Or " Low voltage warrning" message
(mine is set @ 20%battery)
and should RTH @18%
also My home screen on my Nexus7 pad I have two battery Meters ...
1 is the time line Bar that show Distance left to HP
2 Voltage meter Icon
and on the controller i have a Voltage meter unaware of the two bad cell every thing looks well
@ 23 Minute mark
Never recieved a" Low voltage Message"
The battery did charge up and will later put it in mavic and look at the 3 cell through DJIgo app
I welcome any Positive feedback
