Hi all from Leyland. UK
Greetings from Birmingham Alabama
Hi all, looking forward to learning from you folks and improving my knowledge.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Welcome to the forum @October! :)
What are you flying?
Hi all, thanks for the warm welcome.
I have an Air 3 and Avata2
I also have a home built dead cat. With a pixhaw2 flight controller.
Plus a host of helis flown ( or hovered in my case) on Futaba systems.
Plus a few monster trucks.
It's a great hobby keep at it.
Just got my A2 Cof C. CAA exam.
Can’t think of anything better than flying after a day at work
Cheers all.🍻
Paul from Leyland.UK
Im in manchester lots of experience in drones
Overspeed
