Just bought Mavic mini SE, havent flown it yet, weather not good here at present.
Welcome from the Hampton Roads area of Virginia, USA. I fly a
Mini 2 and I know the excitement you are going through…
So, you are in Bunbury, the weather is not good, it's Winter there, summer here (90 degrees F -- 33 C). I checked your weather and I can see it's windy and rainy. Don't fly! If something goes wrong, you'll never know if it's the wind, rain, or you…
Be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy and Safe Droning…
