Hi from Croatia
Hi, Mangosa, these guys do have the information.
Hi people from Croatia, new owner of dji mini 3 pro.
I am here for friendship and useful information..
Yep. I had to bust out Google maps to where you're at! Can't wait to see some footage.
Hello from Savannah, GA USA
Since you live in Croatia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Hi, Mangosa!
May I offer you a Big Texas Welcome to the forum!
The Mini 3 Pro is a perfect choice for the novice and expert alike. And its sub 250 gram weight will sidestep many regs in Europe., UK, and elsewhere. Totally the drone to get. I fly a Mavic 2 Pro, but I'll upgrade to the Mini 3 Pro with the RC Pro controller.
Just ask, and our world-wide membership will help you advance as a pilot and photographer. Glad to have you aboard!
Rich R (AKA Hauptmann)
Welcome to the forum! :)
iconautomatedsolutions
