Hi from high in Utah
jwanderson88
Fairview, Utah
I bought an old Vivitar Skyview drone (unused) at an auction. It sat for a few years. Finally I figured out the GPS thing and got it up in the air. It was so old that there was no app for it. I decided I had to either drop my hobby before it even started or upgrade. I upgraded to a DJI Mini 4 Pro. I've only had it a couple of weeks. I'm nervous about damaging it or losing it.
Hello from the Crossroads of America jwanderson88.
If you haven't done it yet, you should take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Good luck with your future flights and welcome to the Forum. :cool:
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Utah, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
I've been flying for years, and I still get a bit nervous every time I take off. I'm OK with that, because I use it to make certain I've done all my preflight checks and fly carefully.
As others have mentioned, there are legal requirements for flying which you should comply with.
The best way to overcome nervousness is to practice in a spot where there are no hazards. Somewhere wide open (no trees, buildings, wires, and so on) with no people around. It might be a bit boring, but when you are developing muscle memory for the controls you don't want excitement. Once you don't need to think "which joystick controls height?" you can venture to more interesting places.
Welcome to the forum! :)
As you gain experience with the drone your confidence will increase. You can also get coverage from DJI that will cover loss and damage.
Welcome to the forums from the bowels of California!
PJ19
