Hi from the Isle of Wight
k12pfc
isle of wight
Hi a newb from the UK I’m an enthusiast landscape/seascape photographer, and wanted a drone to enhance my hobby really, anyway I didn’t do enough research coz I bought a mini 3 when I actually should have got a pro, anyway long story short I now own the mini 3 and the mini 4 pro..gonna have to sell the 3 quick before wife finds out. Lots to learn, watching loads of videos and getting out when I can, believe it or not there’s not many quiet wide open spaces on the island, plenty of beaches though.
... And one of the solent forts a little ways offshore. Welcome to the forum
Hello from the Crossroads of America k12pfc.
Ummm, give one to her as a gift so you can fly together. 😘
It might work. 🤔
Good luck and welcome to the Forum. :cool:
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Until you sell the mini 3, below is the link to all of the downloads offered by DJI for the Mini 3 and the Mini 4 Pro, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the forum! :)
SURV69
