mavicpilots.com
Since you live in the Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
According to DGCA, drones are allowed in the Netherlands, subject to DGCA and EASA regulations. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
I do not know if you are new to droning or an old hand… So, I'll treat you like a Newbie… Also, tell us what you are flying…
Happy Droning…
