Hola from sunny Spain
FF_Shooter
Spain
Site
youtube.com
Hi everyone.
I’m relatively new to flying drones, but I’ve been bitten by its bug. Flying those little creature relaxes me. Watching the world from above gives me goosebumps.
I’m an amateur photographer/videographer. I shoot RAW and I’m full-frame sucker. Hence the name FF 😉
I’m glad to be here among you all.
All the best,
O.T.
Welcome to the forum from the beautiful woods of Maine,USA!
There’s many knowledgeable members willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response.
My only advice is to practice in an open field to build your confidence before attempting any tight restrictive adventures!
Fly safe and stay safe!
Whenever I look up drone-related question, it directs me here. I’m sure I’ll have fun and gain experience here. ✌️
I practiced twice close to my house, 2 session were enough for mini 4 pro.
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
The link to Spanish law is outdated or inaccurate.
Please send me the correct/current link and I will replace the old one with the current one.
Here’s the official one.
Thank you, I have updated my reference sheet with the new link and I reviewed it, luckily Google Translate lets me click on the English Translation...
Mamanov Ramazan
