Home point update ???
Shadowcatcher
Ohio
Question, when the voice on the controller ( I call it Alexa's sister ) says home point has been updated, should I believe it or manually go into the menu and set home point??
Thanks
Check the location of the H on the map to ensure it has been set to the correct location.
Reactions: WAXMAN
I always interpret that voice as "now the wonder tech have placed the H on the map" ... then I do what she tells me ... I check the map my self ;)
the most important thing is for her to say it ,and check the screen for sats locked before you take off
Reactions: PAW
Thanks
Does the verbal confirmation not say “The Homepoint Has Been Updated, Please Check It On The Map”?
Does that not answer your question?
Just glance at the map for visual confirmation the correct point has been recorded.
Yeah, what @Simmo said is really what you are checking. If it's facing all weird, then there may be some mag interference?
Jiddles
