Isn't the problem that the downward position sensors are trying to do its thing when there isn't suitable lighting to do so.
I experienced similar problem at low altitude in dark, when I turned the sensor of it started to behave as expected.
The sensors don't have some auto off function so they're still trying tough it's dark, they're just not successful at it.
you are probably close to the mark. i only have the landing area check turned off not the whole OA. (stops the auto land initiating at altitude in 500 firmware so i am told on here).Isn't the problem that the downward position sensors are trying to do its thing when there isn't suitable lighting to do so.
were you hovering over damp/long grass or wet asphalt?The same thing happened to me last night. Its vertical positioning was not stable at all. This was at dusk.
In my case, i take off from a paved patio (no rebar) but the rest of the garden is grass.were you hovering over damp/long grass or wet asphalt?
Regards,
-d.
The ultrasonic sensors on the bottom are the main vertical stabilizers in low level flight and the two cameras on the bottom help with horizontal movement. I live in the high plains but I have one patch of land, a couple acres that I keep tall for the foxes and whatnot and my mavic does not hover as well over that patch or with the morning dew. With asphalt I think when it is wet it refracts the sound and can make the drone unsteady.In my case, i take off from a paved patio (no rebar) but the rest of the garden is grass.
Maybe it does twitch more over the grass than the patio, i will have to try it out when i get a chance, i cant do it tonight as i used all my batteries today.
Regards,
-d.
These opinions are strictly my own, and while based on empirical evidence are in no way to be construed as professional advice or meant to offend.
