The only options I'm aware of are 4:3 and 16:9 aspect ratios. Anything else has to be done afterwards. I use snapseed for quick image editing on my phone.
Doesn't Instagram crop videos automatically, whether you want them to or not? Anyway, if that's a useful function for using Instagram, I'd bet that there are probably apps specifically designed for cropping a standard 16:9 video to the right size, since squares are definitely not a common camera format.I use a lot of social media such as Instagram to post photos and videos.
is there anything I can adjust in camera settings so it fits the screen better and is not shot with a wide view?
iPhoto does it to any shape or proportion you select.Doesn't Instagram crop videos automatically, whether you want them to or not? Anyway, if that's a useful function for using Instagram, I'd bet that there are probably apps specifically designed for cropping a standard 16:9 video to the right size, since squares are definitely not a common camera format.
Ah, for video too? I had never looked at the settings for my Samsung phone, but I see that it does have 1:1 as an option for photos, but not video.iPhoto does it to any shape or proportion you select.
I'm not sure what you mean. The camera sensor has a fixed rectangular aspect ratio, so anything else is going to be a cropping of some sort, whether you do it or the camera does it. You can crop a full-height square in the center of the 16:9 image, and that's the largest size you can get for that aspect ratio.There are loads of cropping apps however it doesn’t blow the original image to the size I want?
it’s annoying because the aspect ratios available are normally for screens.
So, it sounds like you want the same horizontal field of view as the 16:9 format but extend the vertical field of view until you have a square? Given the physical limitations of the sensor, the only way to do that would be to use a wider angle lens so that you start with a wider and taller image.essentially, I have to cut out vital parts of the photo to get the shape I want.
for example close up shots are hard to crop and shape, without cropping key parts of the image. Is there no way an image could be stretched in its original form to the size I want?
In camera settings turn on the grid and then using it to help frame your pictures with square crop in mind. Crop after.essentially, I have to cut out vital parts of the photo to get the shape I want.
That is really the only way to achieve the results that are sought. Otherwise the image has to be distorted in some dimension.In camera settings turn on the grid and then using it to help frame your pictures with square crop in mind. Crop after.
Yes, image sensors are typically 4:3, and the Mini's is 4000x3000 pixels, so 16:9 video must be a cropping. (And actually, it's a re-sized cropping -- the sensor is large enough for 4K video but it's resized to 2.7K 2720×1530 or 1080p 1920×1080. This is why the Mini video compares favorably with 4K camera drones when both are viewed at 1080p: it is a 4K camera even though it doesn't support recording that size.) For stills, however, you can set the aspect ratio to 4:3 and get full-size 4000x3000 images, so taking a 3000x3000 crop from those will be the largest square images Neel194 can get.That is really the only way to achieve the results that are sought. Otherwise the image has to be distorted in some dimension.
A while back it was pointed out to me that a 16:9 is actually a segment of the 4:3 image anyway as the sensor can only capture so much and it is generally the 4:3. It was suggested to shoot the 4x3 and then crop out the 16x9 you want if you want wide/full screen. The issue is visualizing the finished image. I was directed to FastStone editor which has a built-in crop function to crop accordingly.
It looks like VLC Media Player can do it. I have not tried it but found a few videos showing it done.I use a lot of social media such as Instagram to post photos and videos.
Everything I've read says that Instagram always crops to square -- apparently a bad solution to the problem that so many people don't seem to know that you can take photos and videos with your phone held in landscape position -- and that you should, if you intend to upload them anywhere. Otherwise, not only will the image typically be displayed using only 1/3rd of the available area, it will have the rather annoying characteristic of looking like you're viewing through a partially open door and can't see what's happening on either side. Instagram "solves" that problem by simply discarding whatever won't fit in a square, trading one problem for another.Can somebody explain to me why photos on insta can be landscape or square for MavicAir2 but if i looks DJI official insta account most photo are vertical at 4:3 aspect ratio? How can I get the long vertical instagam looking from my MA2?
