How to quickly format SD Card with DJI app and Mavic Pro?
PhilMTX
Hi everyone,
I made a quick 30 seconds video about how to format the SD card using the DJI app on mavic pro.
I hope, you find it helpful,
Phil
Sorry if this is a stupid question, but is it really necessary to format the SD card, they usually work right out of the package don't they? Or is this to erase existing material on the card, to start fresh, after everything is downloaded?
It is to start fresh, once you have dumped the data somewhere else.
Note that it is good practice to only format the card from the device it was last use. For example, format your micro SD card on the drone, and not your Gopro you may have used. And vice versa: don’t format a micro SD card you used in your Gopro into your drone.
Not mixing them up is a good idea...
If you format the SD card in the Mavic using Go 4 it insures that it is set up properly for that combination to use.
famagusta
