How to rollback Mavic firmware
Since 01.04.0100 came out I've had mix module, pano & parameters
Contributions
PayPal Donations - > [email protected]
Bitcoin Donations - > 1LrunXwPpknbgVYcBJyDk6eanxTBYnyRKN
Bitcoin Cash Donations - > 1LrunXwPpknbgVYcBJyDk6eanxTBYnyRKN
Amazon giftcards, plain thank yous or anything else -> [email protected]
Any donations in excess of the drone cost, will go to Special Olympics!
First thanks to HH for all his hard work on this. Second, I assume I still need to open up my MPP and install an SD card before I can do this?
My *guess* is yes, but you might want to just stand by for a little bit; there's some indication from the NLD guys and others that mods may be possible up through the newest firmware versions. Maybe. But if you're trapped with 1.04.0100 now, I think you should be able to downgrade to 1.04.0000 and at least unshackle yourself from the anti-rollback nonsense.
So unless you've got a pressing reason to downgrade now, hang in there to see what becomes possible for you without having to mod your hardware and void your warranty.
I'm on .700 but interested in the goggles improvements and maybe even the Quickshots, but don't want to step into a bear trap or give up precision RTH, so I'm sitting tight and watching to see what shakes out of the New Years' gifts.
Reactions: Ping^Spike
I haven't done anything really, just try to help where I can with information I've picked up off others
Its @jezzab & @jcase that have done the hard work
Without an SD card you can only use 1.3.1000, 1.4.0000 or 1.4.0100 at the moment
As @PT_Mavic said people are currently working on changing that
https://github.com/CunningLogic/DUMLRacer/raw/master/DUMLRacer.jar
java -jar DUMLRacer.jar AC
java -jar DUMLRacer.jar RC
That removes block then use DUMLdore
He bought a mavic to help out and would like contributions to recoop costs if possible, details in program
Not really bothered about downgrading , more interested in the how, ive downloaded the file from the link above, but cant seem to find any intructions as to what to do with it, is there a link possibly?
Hi, I tried to make it as direct as possible, but for those that havent used java jars directly before it might not be so direct.
the program is DUMLRacer.jar, you launch it with java like - java -jar DUMLRacer.jar
It takes on arg, either AC or RC, AC for drone, RC for remote.
When running, it will ask you to select the port for your drone.
Then it will do it's magic.
or if you were asking for specifics, I left it fully open source
Reactions: Exphantomflyer
Couple quick questions:
Is there any parameter I can set to get rid of the RTH beeping?
Is the only serious option for Platinum low-noise props the genuine DJI ones?
Reactions: Borntofly
DUMLdore v2.12
Downgrading from V1.4.0100:
Choose new jcase anti-rollback method
Wait for it to defeat it (may take up to a couple of minutes)
Normal start flashing dialog will show
Upgrade will begin
Close DUMLdore
Check with Assistant2
After the upgrade Assistant2 will probably show the firmware as:
1.4.0100-
It has downgraded but some modules were skipped
Close Assistant2
Start DUMLdore and flash as per usual
Say NO to new rollback method (we dont need to do that now we can just do it the old way)
Upgrade will begin
Close DUMLdore
Check with Assistant2 (it will be a much faster flash than before)
Upgrade will complete and show the correct firmware
If you are referencing the post above, its copied & pasted
As with most things, its expected that you will only install newer versions not older so the process is typically called updating / upgrading
I personally dislike the term upgrading in this sense as it suggests that you will get more which isn't always the case, to me its an updating, installing the latest
I personally haven't tried that one yet & yes
I'll try tomorrow
RC remote control
AC aircraft
DUMLRacer is a tad iffy atm, but not dangerous. It will get better
I'm really new to drones and this weird setup DJI is using, and I havent tested it much at all. It does work, probably most solid on osx, but ive got reports of it working on windows from Haloweenhamser
is it working with mac??how thnx
Reactions: Mike357
On windows open cmd
Set directory to where you have put DUMLrace.jar
I put DUMLrace in c:\ for easiness so just CD.. to go upto c:\
java -jar DUMLRacer.jar AC (for aircraft)
java -jar DUMLRacer.jar RC (for remote)
how about on mac where can i get firmware AC
Marlin
