Huawei MediaPad M5 10 DJI App Map Issue
0plus6
Has anyone else experienced map being in the wrong location? Appears to me the map should be on the lower left where the controls are, yet it appears on the right covering the play button.
All I get from DJI help is to check the approved tablet list.
Thank you
Thank you for that! Looks like we have the exact same issue, with the exact same results. 750 DPI renders great for DJI app but settings doesn't work properly.
Appears lowest I can go is 720 DPI and render properly. Settings still not right though.
I ended up with 605. Almost standard, works for all other stuff and the map is almost correct... :)
605 seems to be the magic number. 606 is default. So far so good. Thanks for your input and help!
Reactions: StefanG
Thank you
Hi, what mount are you using with huawei media pad m5 tablet?
Isnt it too heavy? Can you show some screen how does it look like?
Greetings.
mini3user
