I messed up...
Hefner413
So I landed my mavic on top of a structure that I could not access by foot (dumb idea #1). The prop was up against a rod, obstructing my ability to take off. My plan (dumb idea #2)... since I had no way to access my drone and I did not want to just leave it... I decided to buy a second mavic to retrieve the first... yeah, I know, bu bear with me. So I made a 3 foot wire hook and flew up and caught hold of the mavic well and was flying it toward me. It was going ok, but it was going slow and I dropped it a couple times during the attempt and had to pick it back up a few times. I received a warning of "Battery: Over current during discharge," but otherwise, no issues. I was getting low on battery, so aborted the attempt and began to descend at about 16% battery from 60 feet. I was descending straight down and halfway, the drone seemed to become unresponsive and flew straight into the concrete and hit very very hard. I reviewed the flight log and the battery rapidly discharged from 16% during descent. It reported that it was auto landing, but that was the only error message. I had reversed the throttle prior to crash, but no response. The battery read 4% after the crash. I've flown DJI for years and have done various dumb things like this, but have never had a DJI crash while landing like this. Any thoughts?
Reactions: wisesafe
To be able to say anything with surety, we'd have to see the flight logs.
Did you disable the downward facing sensors when you mounted something below the drone?
I thought that also, but the more I thought about it - the mavic still should have been able to respond to my upward thrust despite the downward sensors.
****, that sucks. One of the more interesting accounts I read lately though. Sounds like the weight required more current than the battery could provide for any amount of time.
6m27 is where I begin descending at around 99ft and 16% battery. It hit the ground at 6m35 and 4% battery. So maybe about 8 seconds total.
@Hefner413, did you begin your rescue flight with 60% battery? Did you ever charge that battery fully?
If not, SmartBattery might not calculate the % correct.
According to the logs, you took off with 60% Battery - Cell#1 = 3.8v, Cell#2 = 3.79v, Cell#3 = 3.8v
Everything looks normal, but at T=137s, the batteries reached 3.5v each, the remaining percentage was 50.
This is not correct, at 3.5v (each cell) it should indicate something below 30%
But the flight continues until T=335s, where the individual cell voltage drops steady until T=380s all cells reached around 3.0v. At that point the aircraft should have never been in the air anymore.
Also the SmartBattery algorithm should have warned you before with a pop-up message and later on activated forced landing.
At T=396s the log ends with battery voltages of Cell#1=1.71v, Cell#2=1.39v, Cell#3=1.85v
Something is wrong with that battery. Either you did not charge that one fully, or the battery is/was faulty from the beginning.
Many issues with the second flight...
As mentioned, you started to fly at 60% battery. You were not at 60 feet at 16%, you were at 10% at 100 feet. At this point the Mavic will only descend and you can only slow it down. As you were descending, the battery was about to turn off. It is probably a good thing that the Mavic descended as quickly as possible and actually landed otherwise the battery would have turned off mid0flight.
I see no issues with the way that the Mavic behaved.
So, with the cells < 3V, wouldn't that be damaging the batteries?
Yep, that battery went to the happy hunting grounds.
I'm impressed that you're prepared to go public with this!!!! :p;)
Probably should have used a Phantom for the rescue op. More power and more places to hook things too -- but hindsight is always 20/20. Just out of curiosity, where did you land the first one so you couldn't get it? Top of a tower? Private building?
Yeah, I only did a partial charge, never thinking about that outcome possibility. Add that to my list of dumb ideas here. Thanks for the input all.
Hey, do me a favour. The next time you’ve got $1000 you want to throw away, send it my way!! :rolleyes::)
Bummer. But you should treat your flights as if you were actually inside the aircraft. You took a lot of chances.
gomezstatiq
