I want dji mavic 2 zoom leg replacement
the Mavic2 Pro ,and the zoom are the same as far as the arms and motors go so you should be able to find them under M2P
Reactions: THE CYBORG
I don’t need the arm I will pull off the leg and I will install it on The Front right arm
Because the broken only the arm not the leg
I seem to recall the leg by itself is not easily replaced, especially with the LED glued in place.
For the effort vs cost, better off replacing the entire arm.
I saw this tutorial and I feel its easier than replacing the whole arm, unless I'm missing something! What do you think ?
The Grumpus
