That was the 1st accessory I bought after I could not stand the fiddly original one.There is little that is more frustrating than trying to attach a gimbal cover to a Mavic 2 Pro with the "swinging door" though it does keep the gimbal steady in transit.
Is there a 3rd party gimbal cover for the Mavic 2 Pro?Nifty!![]()
That was the 1st accessory I bought after I could not stand the fiddly original one.![]()
Oh, there are plenty ...Is there a 3rd party gimbal cover for the Mavic 2 Pro?
It doesn't appear they are available in the US. But there must be a reason why DJI created a cover that stabilized the gimbal within the cover. A single piece cover would seem cheaper to make and DJI's bean counters seem to go with trimming cost over quality and function.Oh, there are plenty ...
I have chosen this one and added additional slim pads on the sides and the bottom which made a perfect fit.
Thumb keeps the camera straight so it doesn't pivot and catch on the cover when putting it on.LOL, what am I missing here? What is actually being done that is "different?" The clip is so fast I'm not sure what I am seeing.Never has a problem putting mine on after the 1st try.
EDIT OK, I just ran it in slow motion (never noticed that "feature of YT) and still can't see what is the special move? Maybe the "thumb action?)![]()
Some people like me had problems with that, and wanted to help others. Glad you found it humorous.
You don't...so you just keep doing you.![]()
I do the same… using the foam to keep the gimbal in the correct position.i kept the foam from the gimball when i first receive my M3P , i use it to keep the gimbal stuck then i can use the gimbal cover, its cheap and work fine.
I also retained the foam for both the M3P and M3Cine.i kept the foam from the gimball when i first receive my M3P , i use it to keep the gimbal stuck then i can use the gimbal cover, its cheap and work fine.
