I'm currently in SoCal, however, I'd like to see the Pensacola area restrictions prior too going there. The map only shows airspace in my current SoCal area. Is there any way to view outside the local area in advance? Thanks.
All the apps for checking airspace restrictions allow you to select the area of interest. Look for a search feature or scroll the map. Which one are your using?I'm currently in SoCal, however, I'd like to see the Pensacola area restrictions prior too going there. The map only shows airspace in my current SoCal area. Is there any way to view outside the local area in advance? Thanks.
You'll need LAANC authorization to fly within the circular areas shown below. Note the 0' AGL limited areas.I'm currently in SoCal, however, I'd like to see the Pensacola area restrictions prior too going there. The map only shows airspace in my current SoCal area. Is there any way to view outside the local area in advance? Thanks.
