IMU error ACC0 0.01
RBT_Richard
Cartagena
I had a head-on collision with the drone and now the gimbal does not stabilize the camera.
Tried a factory reset, compass calibration, and IMU calibration, and all the steps completed successfully.
When I turn on the drone, the check does everything correctly. All 3 gimbal motors work, but then the gimbal does not stay stabilized when I move the drone.
After successful verification, it found these errors:
Compass: Normal
IMU: restart the drone
ESC Status: Normal
Visual sensor: normal
Stabilizer Status: N / A
Attached 3 videos to see their behavior:
Video 1
Video 2
Video 3
The back up IMU is working, IMU 1 is dead but the camera gimbal must be damaged from the impact
So if I change the IMU module it should be fixed. Not?
This:
IMU 1 might be just stuck from the crash
Might be time to "hit" the imu by hitting the AC to free it up
I've tried and it still doesn't work. I have noticed a small fault in the camera motor, I just bought a spare part to change it. When I change it, I will tell you if the problem is also solved the IMU.
I have been able to solve the problem, although the "IMU ACC1" error remains. I changed the piece in the photo and also changed had this piece bent because of the blow.
Analogdesigner
