Inspection
Cali-Mavic
PreFlight inspection is very important, you'll never know what you're going to find.
Reactions: mlaczek
Wasn't your screen name RodDogg previously?
Now Cali-Mavic? How/why did you switch?
Can you explain what was broken that you found on preflight inspection? Want to make sure I learn from your posts.
Thanks
Thanks
LMAO
On the top of the propeller in the center I noticed a crack going across comma I remove the propeller and noticed one of the tabs that lock and hold it in place was broken off and down inside the motor.
How many flights or hours do you estimate so far on this prop?
Good question, I don't think it was excessive hours , a couple flights ago I was backing up against some trees I thought my propeller touched one of the branches but when I looked it didn't seem to have caused any damage but then again I was in the shade I must not have seen it. Today when I was indoors I had my kitchen light on and I could see better, the crack showed a lot clearer.
Reactions: Skrems
TPS
