Intermittent IMU Calibration warning
Zonian
Went out to fly Mavic in the back yard last night to burn off a battery, and I received several intermittent IMU calibration warnings & tail light was blinking red as Mavic was sitting on the ground after I turned it on. After a minute or so as I was fiddling with GO4 to set disconnect to hover, the warnings went away all on their own and I got green blinking light. It flew OK, I never went more than a meter or 2 high. Seemed to drift on all 3 axis way more than normal; I attributed this to VPS in the dark...correct???
I have not done the latest FW update...
This IMU calibration error has never happened to me before. How concerned should I be? I tried to look in the flight logs for something, but really not sure what I should be looking for that would indicate a problem??
I will try again later today and see what happens...
Check your IMU status on daylight condition, if something is off or abnormal reading....re calibrate.JMHO
tflys78
