Intro and Hello
ajdavies
Just introducing myself as a new member. I live in the San Francisco area. If any other members are close by and are looking for flying companions please reach out. I’ve had a DJI Air 2 for a few years now and have recently increased my collection. I’m more of a novice at this point, but I’ve already managed to get some very nice footage recorded. I’m looking forward to flying more.
Your words, "I’m more of a novice at this point," so there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
sscott062
