Took off from 200 m on a platform overrlooking andaman sea thailand.
First issue on take off drone turned as it ascended which it has never done.
Second issue minor signal/RC CONNECTION ISSUES yet i was over clear sea 60m above take off nothing at all to disrupt signal
Kept flying as i like to test stuff in safe areas
At 4400m i got the RTH warning and i always turn at this point
RTH worked AC TURNED flew exact line home i had OA ON i decided to turn OA OFF.
At this point the AC JUST STOPPED.
Stayed in hover at 4000 m out over the sea
After 10 secs the AC started back home. Why did it stop when i turned OA off?
No panic as **** happens
But IOS i got a dark screen then black screen at firt i though disconnect.
RC SCREEN showedAC still closing distance on Rth so again no panicmy RTH HEIGHT WAS ENOUGH TO CLEAR ANYTHING AS I WAS OUT TO SEA straight line flight only.
As the AC WAS COMING HOME i investigated further
F&&&& iphone shut off completely no disconnects at all RC showed 20 sats HD 4 bars and RC 3 bars
So what did hapoen?
Iphone 7plus no shade 33 degrees the phone turned itself off mid flight due to overheating.
On realising this i let the Mavic do its thing. When in range i took over flying on RC
I WAS NOT IMPRESSED AT THE PHONE JUST SWITCHING OFF
5 minutes in car and turned on all normal
A warning sign this may hapoen is iphone will go into low power mode first
Hence screen going very darkl barely able to see it
Then
2 mins phone shut down
Flight was 9kilometres
So what did hapoen?
Then
