Yep, you can flip the clamp, or even mount it from the bottom as well on a Mavmount. TRhis one has the clamp mounted from the back. You can even ivert it and had the ipad over your wrists if you wanted.It looks like your spring loaded ipad holder also has a tripod mount so you can use it to hold your ipod on a tripod at different angles. Pretty cool!
I've always just used it as i thought it should be used. I never thought about inverting it and trying to open up the view of the screen on the controller. Guess I just have to spend a few hours this weekend trying different configurations.Yep, you can flip the clamp, or even mount it from the bottom as well on a Mavmount. TRhis one has the clamp mounted from the back. You can even ivert it and had the ipad over your wrists if you wanted.
