IPad mini 2 or mini 4?
Kevin C
St Louis
As I am waiting (impatiently) for my mavic to arrive. I am considering getting an iPad mini. Does anyone know if there is much of a difference when connected to the mavic?
The Mini 4 is considerably brighter and more powerful than the 2. If you're using it solely for your Mavics FPV, a 16gb model is all you'll need however, consider getting one with 4G so you won't have a need to tether to your phones hotspot for data connectivity.
My mini 2 fits OK and works without lags. Thickness is not a problem, but length is almost maximal for original mounts. I hope mini 4 fits too (it's 3,2 mm longer).
Reactions: Rbruz
Is it a requirement that I have data connectivity?
No, you can pre-download the maps of the areas you are going to fly so data access is not necessary.
Moira
Minimum of six months, maybe a year and a half to two years.
It has the same internals as iPad Mini 3, so will likely receive iOS11 around September. If it doesn't, that's your six months.
It probably won't get iOS12, which will be 2018/2019.
Reactions: Mjonesy758
JHW Imaging
