ipad mini 4 last version vs. mavic PRO
Mavicavok
italy
Hi there,
I am heveing issues with an ipad mini4 (last version), it doesn't see the Mavic Pro. It normally works with a holder ipad mini4
Someone can help me with this?
Thanks
Paolo
”Last version“ of mini4 is confusing. Mini6 I believe is the last version.
Above part of your post is also somewhat confusing.
A little more information on what issue you’re dealing with will help.
This may be just a bad cable issue?
Hello, thanks for your prompt reply; I confirm the iPad in use is a mini 6; I tried with different cables without results; the same cable works with an older mini4. The issue is that the App DJI go doesn't recognize the drone.
Hope you can help me to find the solution
Kindly
Paolo
I have a similar issue from what you describe.
The mini6 will recognize my Inspire2, but several other DJI aircraft are not recognized.
I‘m still trying to sort this out. You are correct that it is not cable related.
Meric
