Is everyone doing battery deep charge cycles?
PilotSmith
Surprise, AZ
with DJI Mavic Is everyone doing battery deep charge cycles?
also how do you do it?
There is no benefit to deep discharging Mavic batteries.
Reactions: ZUCSTA
To keep lithium batteries at their best you don't charge above 80% or drain below 20%
Down at 1% you can do alot of damage
If a cell goes below 3v then it probably won't recover
I do a deep (8%) discharge every 20-30 flights. I usually hover until it gets down to 8%, others just leave the drone on for an hour or two on the table to let it get down that low.
@Haloweenhamster is right, anything below around 8% could kill your lipo. The Mavic will usually turn itself off when it gets down to 5% just due to the amp draw.
famagusta
