Is the Mini 5 Pro a sub-250g drone?
Ever have State Police, FBI, and Homeland security show up at your door all at once??? I didn't think so. LOL
For what? Because you were flying a drone LEGALLY?
I HAVE had the police and FBI show up, though. Wasn't for a legal drone flight.
I flew a couple of hundred feet over the 400ft limit a few times. They wanted to make sure I wasn't engaging in something nefarious. Now I'm on their radar unfortunately so I'm looking to fly without remote ID
And you think that flying without RID is going to take you off their "radar"?
Reactions: Bad Santa
So you FAFO'd and now you want to have the ability to FA without them FO?
I see.
Why not just follow the rules or man up and accept the consequences?
Reactions: anotherlab
Have we don't this one yet?
🇨🇦 Canada: Transport Canada SET Branch Newsletter: Issue 3 — October 2025
Transport Canada SET Branch Newsletter: Issue 3 — October 2025​
Transport Canada SET Branch Newsletter​
Table of Contents​
  • Knowing your drone operating weight
Drone pilots are responsible for confirming the operating weight of their drone. The operating weight and capabilities of the drone, distance from bystanders, and airspace rules define your category of drone operation. Each category has a different set of rules that drone pilots must follow.
According to the Canadian Aviation Regulations (CARs), operating weight means the weight of a remotely piloted aircraft at any point during a flight, including any payload and any safety equipment that is on board or otherwise connected to the aircraft.
In Canada, drones that weigh less than 250 grams are called microdrones. If the operating weight of the drone is 250 grams or more, it isn’t a microdrone. If you wish to operate a drone that weighs 250 grams or more, you must register it and obtain a Pilot Certificate. If you are concerned that your drone might weigh 250 grams or more, you should register it and obtain a Pilot Certificate – Basic Operations or Pilot Certificate – Advanced Operations.
In addition to following Part IX of the CARs, drone pilots are subject to all federal, provincial, territorial and municipal laws that may apply, including with respect to privacy and trespassing.
But, the fact that the manual states that RID is not broadcast with the standard battery suggests to me that it's a problem with the drone's programmed control logic rather than an intentional part of the design. If that's the case, a firmware update may resolve it.
Both are true.
When the manual was written, DJI did not intend to broadcast RID with the standard battery because the total weight was designed to be under 250g.
However, when it became clear, that even with the standard battery that it would be over 250g, they changed their minds and disabled the code that prevented RID broadcasting with the standard battery, but failed to remove that statement from the User Manual.
They could easily create a new FW update at any time to disable RID with the standard battery, consistent with the original User Manual.
However, they chose to instead remove the conflicting sentence from the User Manual.
Problem solved, except many purchasers relied upon the original User Manual and bought what was supposed to be an RID free drone that would not require registration. Now it not only broadcasts RID but also requires registration. Both were material misrepresentations.
DJI's response: "We so sorry."
If I thought DJI would address it with a FW update, that would be good but they can't answer that question when I asked them.
They could, but they have chosen not to. They simply deleted the conflicting sentence from the User Manual. It no longer states no RID with the standard battery.
You guys see how something such as RID always on fw change can change an entire product? The only reason I BOUGHT IT was because it was sub 250 and didnt need the RID beacon tattler. If i knew they changed it to always on I would have baught a f****** larger drone!
Reactions: GadgetGuy
Drone vendors can not disable RID in the US if they know that the drone would weigh over 250g or over. If they chose not to, they would violate the RID rule imposed by the FAA.
I created a thread about Mavic 4 Pro launch challenges but I did not create one for the Mini 5 Pro. We don't need one because the 250gate speaks for itself and it will never be forgotten; no one will ever claim the M5P launch was perfect and flawless. It's probably one of the biggest launch blunders in DJI drone launching history and sadly, DJI is probably thinking about how they can quickly put this behind them. And you may not be happy with their solution.
It was a serious production decision failure. Staying below the 250g threshold should have been one of the rules that "shall not be violated".
Upgrading the speaker component was an easy one to say no to. No one buys a Mini for the sound fidelity. That functionality could have been in the remote.
How important were the quick-release props? Would people give up 2g from the battery to allow the quick-release props?
They must have made the decision before the moulds were made and then just gave up. When I compare a mini 4 pro and mini 5 pro the 5 contains plastic that isn’t in in the 4. The ventral slots on the 4 are missing on the 5. Internal ribs that are grooved in the 4 are solid in the 5. There are covers on the rear leg hinges and other screw heads hidden on the 5. Yes, I know these don’t weigh a lot individually but they’ll add up and weight saving is an incremental science.
Understood.
However,
1. They pretend not to know, telling us that it is 249g +/- 4g and that we should weigh our individual drone to determine its true weight, and stated that it would not broadcast RID with the standard battery regardless of weight.
2. The drone is not being sold in the U.S., so why are they obligated to broadcast RID on a drone not intended for sale in the U.S.?
3. I strongly suspect that the Mini 5 Pro in the EU does not broadcast RID, based upon the fact that the only version of the User Manual that had the no RID broadcasting statement removed was the English version. All other languages remain the same as on September 15, still stating no RID broadcasting with the Intelligent Flight battery. The Plus battery is not available in the EU anyway. Can anyone confirm my suspicions?
Reactions: mavic3usa
I was responding to "They could, but they have chosen not to".
You are arguing legality, rather than capability. My point was that a simple FW update could have made the drone consistent with the original User Manual, such that it would not broadcast RID with the standard battery. Surely, that was their original intent, until the drone got too fat!
Finally, the truth comes out about "the rest of the story!"
An upgraded speaker and snap-on props that added 4g of fat to the 249g drone.
I would happily trade both for a true 249g Mini 5 Pro that did not broadcast RID!
Reactions: Diver
keem21
