Jerky yaw movement in Litchi waypoint missions solved for DJI Mini
DJ Wes
Springdale, AR, USA
Site
www.litchiutilities.com
I just saw this in the Litchi forums. It is a resourceful solution to the jerky yaw movement in Litchi waypoint missions. All you need is an older Phantom that properly supports onboard waypoints:
What's frustrating is it has been demonstrated this can be fixed, but the fellow that did it had to reverse-engineer part of the DJI SDK, then access interfaces not normally exposed, or supported to be directly used.
This was done several YEARS ago. Why no progress has been made in getting this implemented in the supported interfaces in the SDK, or any status/progress update as to what's happening.
It makes Litchi unusable.
Bit late to the party but I've solved this... in post and it works very well. Take the complete video.... put it through Movavi (free) click on stabilise. Go for max stabilise and... apply... excellent results.
Reactions: Yaros
Davinci resolve stabilization also works pretty well in most cases.
Absolutely it does but boy is it slow in comparison.... I've tried both and genuinely cannot tell the difference but Movavi is way, way quicker whether its 4k, 2.7k or 1080p
GLobus55
