I won a (like new)
Mini 3 Pro from MPB.
Congratulations, you are in for a lot of fun and it will opemn up a whole new aspect of photography…
mavicpilots.com
Hhere is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
