- Joined
- Nov 22, 2017
- Messages
- 337
- Reactions
- 44
Which one is better practice: keeping the propellers on or taking them off while transporting in a closed case with gentle foam cushion?
On, otherwise it would defeat the purpose of a quick to launch camera, for me. I feel it was designed that way.Which one is better practice: keeping the propellers on or taking them off while transporting in a closed case with gentle foam cushion?
The Platinum props feel a bit more fragile compared to the standard props (they probably are more fragile). Also due to its shape, the tip is prone to be damaged if you are not careful:can you please elaborate why? thank you.
+1Standard props, I leave them on. Platinum props, I remove them (because of the build quality and the shape of the Platinum props)
I don't have a MPP so I am not 100% sure, but I believe the answer is yes.can you use standard props on platinum?
Only for transporting. Unless you bring your Mavic everywhere, certainly removing and installing the (Platinum) props a few times a month won't cause any extra wear and tear. As I wrote above, with standard props I just leave them on.more chance for wear and tear taking them off all the time
As lolo780 mentioned in the other thread, the problem is with the trailing edge of the rear blades hitting the heat sink. Some people reported their Platinum props got damaged at the trailing edge.I leave them on. I looked closely at the platinum vs the originals and didn't see any difference in the amount of pressure put on the props or how they folded up.
