landing leg & black wire aerial
Haloweenhamster
MK, UK
Hi I need a left landing leg and the PCB or PCB and cable for the black aerial
Will it be easier to source and replace the leg and aerial or whole arm
The leg is missing so I can't repair it and the cable has pulled the pads off the PCB
If anyone is going to offer parts I also could do with a gimbal yaw cover
I'm in the UK
The one in the rear is GPS. Well the one in the top half of the shell at least.. The bottom half looks like it houses the WiFi.. You can see the bottom half WiFi one in these images
Mavic Gimbal Video Fix
Go to Ebay and search for "dji mavic parts." You will be surprised that almost every part of the MP drone can be purchased separately, and at very reasonable prices! Good luck!
Full arm for leg and aerial, middle frame, gimbal ribbon are all easy to get fan is pricey and not got connector fitted
Whilst I was fitting the gimbal ribbon I noticed that one arm was bent and gimbal doesn't want to separate easily
osje
