I have a standard daytime landing pad that does not have integrated lights. I'd appreciate recommendations on how best to illuminate the landing pad for night landings.
@MA2 317 Thanks! Good idea on cheap holiday lightsAs mentioned by old man mavic , depending on what you're flying, it should have a "landing light".
If it doesn't, a simple flashlight or worklight shining on the landing area should suffice.
Story time...
I had an exciting 30 second flight with my Spark a long time ago at night due to poor illumination of the launch / land area
After that, I hand launched and landed on the ground with a flashlight with no problems.
The bottom visual sensors need light to see the ground to land safely.
If you need a lighted landing pad, it's holiday times now and you could purchase a battery operated string of lights to wrap around a pad.
Good luck with your night flights.
Sometimes when landing in the dark the underbody light is so bright the drone will not land.Iturn off the light and it lands fine.Or I turn it off and illuminate it with my phone flashlight.M2PI have a standard daytime landing pad that does not have integrated lights. I'd appreciate recommendations on how best to illuminate the landing pad for night landings.
I have a reflector for the bottom light of the M2P it sends a fair bit of the 'beam' forwards..........it is a BAD IDEA to catch tha beam with your eyes at night when the drone is reasonably close lol.Sometimes when landing in the dark the underbody light is so bright the drone will not land.Iturn off the light and it lands fine.Or I turn it off and illuminate it with my phone flashlight.M2P
I decided to make a dedicated launch pad, so I started with a 4' x 4' plywood base, recessed LED's and a Bluetooth module I bought online. Painted it fire engine red and sealed it with epoxy resin. I control the LED's from the software I side loaded on my controllers...works really well.
@HDrone: impressive work. TY4 feedbackI am fortunate that I live in rural Colorado. We have some acres and I can pretty much fly when and where I want. Sunsets are stunning here and I like to launch right after sun down to capture the beauty. I decided to make a dedicated launch pad, so I started with a 4' x 4' plywood base, recessed LED's and a Bluetooth module I bought online. Painted it fire engine red and sealed it with epoxy resin. I control the LED's from the software I side loaded on my controllers...works really well.
Sounds just fine. The accouterments may not be necessary but if it helps with your enjoyment of the sport, I think you should try it out. Hell., on the bookcase where the drones are parked. I have toy figures of airport personnel from the Playmobil airplane set i found on ebay.
View attachment 157985@waltermitty: TY. Looks like a happy crew. p.s. "pocketa, pocketa, pocketa"
How cool would that be ! My Bluetooth module has 4 channels and I’m using 2 now..Don't forget to add $!0 string of LED pixie lights in sequential mode to replicate approach lights. You can 'chase the rabbit' to the landing pad.
@waltermitty never thought of that. cool!Don't forget to add $!0 string of LED pixie lights in sequential mode to replicate approach lights. You can 'chase the rabbit' to the landing pad.
That night time landing pad looks amazing.I am fortunate that I live in rural Colorado. We have some acres and I can pretty much fly when and where I want. Sunsets are stunning here and I like to launch right after sun down to capture the beauty. I decided to make a dedicated launch pad, so I started with a 4' x 4' plywood base, recessed LED's and a Bluetooth module I bought online. Painted it fire engine red and sealed it with epoxy resin. I control the LED's from the software I side loaded on my controllers...works really well.
