Landing sensors Mavic Pro
Jsnider
Having aircraft problems after crash and rough landing. Had got a release mechanism was hoping to drop water balloons on family had issues launching with ballon due to low profile had to use longer string.... 1st try it blocked down sensor and hard landing 2nd attempt move to quick and it swung and caught blade somewhat controled crash on roof.
Next flight no ballon no launcher just baked aircraft would not hover correct almost went in pool.
Currently aircraft will fly but bounces instead of hovering and can only land manual seems down sensors are not working?
Latest firmware tried Imu calibration new props compass calibration, landing assistance seems to have no effect.
Using dj4 go latest version from apps store on iPhone
Use the DJI assistant software to run a calibration of the vision system, it may have been damaged in the crash
Can’t get it to connect to assistant... on Mac nor pc try to upgrade firmware via DJI go 4 hits 66 percent and does no more.
Why cant you connect it ?
you need to use the latest version of the DJI app as the little fookers made changes somewhere that stops the oldere version seeing the firmware on the quad
DJI app wanted to update controller this morning after update now can’t connect to aircraft. Not bind remote.
Weird thing led indicator on drone where I sync button is red not green?
Ok hmm 20th time now it connects to DJI assistant on Mac, just got controller to bind
Attempting to update firmware now on Mavic Pro via Mac computer
Led now green by sync button wth!!
Gremlins?
WolMTB
