Latest RC2 Update - Zero Satellites after update - Fix
xrubio
United States
Controller: RC2
Drone: Min 5 Pro
I experienced a zero sattellite after performing the latest update earlier this morning. I attempted the following in an attempt to fix it w/o any success:
* Reboot controller
* Powered on/off drone
* Reset/Erase Controller
* Got DJI support and they recommended to refresh both controller and drone firmware using DJI Assistant 2
* Removed/reseated drone battery several times
* Disable/Enable Location toggle switches on controller GUI - Only the one's that the controller allowed.
* Allowed the drone to cool down and attempted the above except for Reset/Erase and Refreshing firmware
After all this, about an hour and a half, you will not believe what resolved this...........
I moved the velocity toggle switch on the controller from N to S. Whatever funk it was stuck on, got out of it and suddenly I got the Controlled AirSpace Pop-up and it started picking up sattellites. DJI support will be notifying their engineers about this.
So keep this in mind when your drone starts acting like this.
What a headache! :(
fototaker Tony
