Thank you. Following your advice I connected the RCPro to WiFi and got update message to v.1.15.0. Should I do it?1.13.9 is the last released version according to DJI's release notes. If a newer update is available, you'll see it on the remote controller or in DJI Assistant 2.
My currently installed version on the RC Pro is 1.14.2. I've received a notice of an update during the last 10 days or so. The popup says it's to accommodate the Air 3S and other updates. I've chosen to update each time. After several seconds, another popup appears saying that the update was not installed. The histogram problem was resolved when I installed 1.14.2.Thank you. Following your advice I connected the RCPro to WiFi and got update message to v.1.15.0. Should I do it?
Thanks. In the meantime, following the pop-up prompt I went through the update process and now I have FlyApp 1.15.0 in my RC Pro. All programable buttons went back to default settings. Other than that all seems to be working fine, including histogram. Test flight pending..My currently installed version on the RC Pro is 1.14.2. I've received a notice of an update during the last 10 days or so. The popup says it's to accommodate the Air 3S and other updates. I've chosen to update each time. After several seconds, another popup appears saying that the update was not installed. The histogram problem was resolved when I installed 1.14.2.
