- Joined
- Apr 14, 2017
- Messages
- 130
- Reactions
- 99
What is the Life Expectancy (Hours) of the DJI Motors on this Drone ?
I've got about 460 miles on mine so far. Same props, motors as when it came out of the box 2 years ago and everything still seems to be tight. I take pretty good care of mine. Never fly in risky conditions and everything goes in a hardshell case for transport. Probably will fly until the M3P comes out.
Since December 29, 2016 my original Mavic Pro has 6,818 miles and 504 hours in the air. I don't fly it much since I got the M2P, but no problems with the motors. I think it is more likely that other components will fail before the motors. I had Thunderdrones replace a shaky gimbal at about 6,500 miles.The big question is "who is flying the drone?" A careful pilot could have hundreds of hours on the drone.
Ask @Robert Granata
If you need to clean out dust I take off the closure plate underneath the motor and use compressed air.You can certainly hear it, if one of the engines does not feel good at some point, it will eventually start to make unusual noises. But I also have my M1P for two years and everything seems to be good. Dust and sand should be avoided as best as possible. So takeoff and landing of dirty surfaces is the main problem. Whenever possible, use a landing pad, a large piece of cardboard or similar and everything will be fine. But also extremely humid climate of long duration could become a big opponent in the fight against wear ...
I hope many follow in your footsteps.Since December 29, 2016 my original Mavic Pro has 6,818 miles and 504 hours in the air. I don't fly it much since I got the M2P, but no problems with the motors. I think it is more likely that other components will fail before the motors. I had Thunderdrones replace a shaky gimbal at about 6,500 miles.
