Must be my 72 yr old shrinking brain but I can’t CLEARLY understand the “above ground” checkbox on the waypoints and when or if I need it. Yes, I have read the manual. It just won’t register.
Yes, absolute correct. I have not been out for a bit, but you are correct. Thank you for the clarification!The height is determined in relation the the HP ... so if the ground rises or gets lower later on in a mission the height for those waypoints always are in relation to the HP & that might not turn out in a good way as the distance to ground will differ if you don't manually take ground elevations into consideration when you set the waypoint heights.
In my example below the ground at waypoint 14 are 11,2m lower then at HP so if I had put in 30m for that waypoint the drone had been 41,2m above ground. But if I check the "above ground" box it will go 30m above ground ... heights stated above the waypoint itself is then the specified 30 first & then within parentheses the height above HP.
To get this to work I think you have to check in according to below in the general settings ...
Thanks .... but I'm still dense. To make the answer clearer for my simple mind: In the "mission hub" in order for the AC to ALWAYS be 121 feet above the marked waypoint or ANY waypoint I have set regardless of anything else would I want the box checked or not checked ?
img upload
