Litchi advice
Ldjuk
Uk
Hi all,
I’m after a bit of advice on litchi waypoints. Does the user have any control of altitude during a waypoint flight or will that stick input from the user cancel the flight.
Thanks.
Hi all,
Thanks.
Throttle inputs are ignored during waypoint missions. To cancel a waypoint mission switch to sport mode or press the pause button
The reason I’m asking is litchi doesn’t have the ground data for a waypoint route that I’ve done. So I was going to rough guess it but be on the controls through the flight for altitude changes. Thanks for your help. [emoji106]
You can manually fly the route and add waypoints with the “add waypoint at aircraft” command that way you can set your heights for the waypoints and then you can move the waypoints to be exactly where you want them in the app
Reactions: charliej
Great advice thank you. [emoji106]
Reactions: charliej
Geoblemes
