Litchi: Heading doesn't match longitude
RoboticTundra
If I have a waypoint with a longitude of -93.130449 and I'm doing 'Focus POI' on a POI with the exact same longitude but 50' north of the waypoint. I would expect the heading to be 0°. Yet it is listed as 355°.
I have a number of waypoints that share a longitude or latitude with their associated POI and yet the headings are 0°, 90°, 180° or 270° only about 50% of the time.
Thanks,
I'm not sure what you are seeing. I set up a few test waypoints and POIs in mission hub, and the resulting headings were exactly as expected. Do you mean the headings in mission hub or the actual recorded headings when the mission is flown?
This is in Mission Hub. Examples:
WP.04 and POI.02 both have a longitude of -93.130799. I would expect WP.04 to have a heading of 180° but here it shows 178°.
Next, WP.05, WP.08 and POI.03 all have a longitude of -93.130990. WP.05 has a heading of 176° and WP.08 a heading of 5°.
WP.09 and POI.01 both have a longitude of -93.130649.
Latitude's are similarly off. WP.01 has a heading of 269° and WP.02 is 268° while both s/b 270°. WP.07 is correctly 90°.
I had curves in but bad headings still exist with straight and WP.01 shouldn't have been impacted anyway.
I did also simple test setup:
WP 1 points to POI1
WP 2 points to POI2
The first leg (WP1-WP2) is exact North/South bound
The second leg (WP2-WP3) is exact West/East bound
POI 1 is on the exact longitude of the first leg.
POI 2 is on the exact latitude of the second leg.
Heading from WP1 to WP2 is exact 180°.
Heading from WP2 to WP3 is exact 90°.
Here the lat/long coordinates from WP2:
Litchi is working as expected for me.
Perhaps you could post a link to that specific mission so that we can take a look.
Mission Hub - Litchi
Thanks. Didn't realize these were publicly accessible.
I'm not sure how you set that up, but the custom heading settings were the problem - perhaps you changed the POI coordinates after adding them. Anyway - if you reset the POIs at each of the waypoints (select a different POI and then back to the intended one), all the headings will be correct.
Thanks for figuring that out. I should have thought about trying that.
I never changed the headings. It wouldn't let me in POI mode. I did change Lat/Long once I got accurate info from the surveyor (who gave me 8 decimal places for 1.1mm accuracy).
Interestingly, if I change the longitude on WP.09 to -93.130500 it moves the WP but keeps the same heading and does not update it to stay fixed on the POI. If instead I drag WP.09 to the same approx location then it does adjust the heading.
That does seem like a bug - updating coordinates of a POI should have exactly the same effect as dragging the marker. I'd suggest submitting a bug report.
dvkhamtruocsinh
