I've saved my Litchi mission and it shows up in Mission Hub of my flylitchi.com account on my phone. But when I load my Litchi for dji mini 2 app the mission is not present in the Missions folder! What am I missing here?
I had the same issue earlier today. Be sure you're logging in with the same credentials in both places. I logged out in both places, shut down the app and the web page, restarted both devices, and found the full list of missions.I've saved my Litchi mission and it shows up in Mission Hub of my flylitchi.com account on my phone. But when I load my Litchi for dji mini 2 app the mission is not present in the Missions folder! What am I missing here?
Thanks. I appreciate the great tips. At least I now know that it'll eventually work.I had the same issue earlier today. Be sure you're logging in with the same credentials in both places. I logged out in both places, shut down the app and the web page, restarted both devices, and found the full list of missions.
If you were using the beta version of Litchi, be sure you've downloaded the released version.
Bingo!!! Thanks again. As you said, I recreated my credentials making them identical. By logging out of Litchi and logging back in, my missions appeared.I had the same issue earlier today. Be sure you're logging in with the same credentials in both places. I logged out in both places, shut down the app and the web page, restarted both devices, and found the full list of missions.
Yikes! Which is it? You must use the beta version with the Mini 2? Or you must use the released version?
