Litchi Orbit Issue
Z06Aggie
Greater Houston Area
Came across an issue this morning where I could not get a Litchi orbit mission to play. I would hit "start" and the drone would orient itself toward the POI, then stop and end the orbit mission. I even tried creating a new orbit mission without any luck.
Got home and noticed the pesky little Sport switch on the RC is toggled on (grrr...). Could this be my issue? Will an orbit mission not play if the sport switch is on on the remote controller?
I assume this is the solution, I just wanted to make sure before I drive back out to try again. Thanks!
Reactions: kissmybrass
Yes if you are in sport mode it won't work, that was most likely your issue.
Reactions: Z06Aggie
destinyrett
