I think I'm going to make the switch to using Litchi for waypoint missions. Seems to be easier to setup and understand than anything DJI has right now, plus the ability to create a mission online is golden.
One question so far. I'm building a mission to follow a kind of winding creek for about 1.5 miles. As I lay down each waypoint I always have to go back and change the heading to match the direction I'm going, which is a pain when you have a lot of waypoints. I will want to record what's in front of me as I'm flying from waypoint to waypoint.
Is there some setting that automatically changes the heading to the same direction the drone is set to go for the next waypoint, or do I need to do each one manually?
Or maybe you can do this in the app after you build the mission online?
If there is no setting for this, I would hope this would be a viable suggestion for a future sw update.
