Locktite?
SW_Drone_Guy
Southwest US
I recently changed the propellers for the first time on my MM. I read the manual and watched the videos and have flown since. All good. I did not use locktite and it wasn't recommended or even mentioned anywhere I looked. Anyone disagree? Should I have used blue locktite?
Thanks
The new props i have put on have had it already on the screws. Be sure you have all the old loctite out before you put new ones in and yes always use the blue not the red.
Reactions: SW_Drone_Guy
You might want to check to see if the Loctite is compatible with the plastic. DJI uses a pre-applied thread lock compound on those screws, not the same as loctite threadlocker 242 etc. See Damage to Plastic Components from Loctite
I use Loctite of several types, but for screws that need to be removed and reattached on occasion, Vibratite can be used up to 5 times
Ok, it's already there and I don't need to add. Thx guys
tflys78
