LocTite
The only thing I've heard regarding lock-tite is the replacement screws provided with the replacement props already have lock-tite on them. You should not reuse the original screws.
That said I would be looking at blue since red is intended for places where the screws are never going to be removed.
Easiest to use the loctite that comes on a stick(similar to chapstick). This is what's on the original/replacement screws.
I see a few "loctite" threads. Where is it initially discussed or mentioned. I don't see it in the Prop Manual or the main manual?
O'Ryan
