Purchased a
Mavic 3 Cine premium combo.....getting acquainted for a while recreational with TRUST, then the 107 test.
mavicpilots.com
Since you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the
Mavic 3, including the User Manual.
Learn and download DJI
Mavic 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
