Lose prop
nap
i’m having trouble with a prop that won’t stay attached to the motor. does anyone have a suggestion as to securing the prop to the motor? It seems to be secure when I am running it on the ground but as soon as I turn it off the prop flips off the motor. I hope this doesn’t mean I have to replace the motor How big a job is that anyway?
Is the small spring still on the prop-shaft? That spring should keep the prop' pushed up and into the 3 slots that hold it in place once you have pushed it on and given it the turn.
[I'm assuming this is a Mavic Pro and you are using stock DJI propellers - yes?]
thanks for the reply. To answer your first question the spring is still attached to the shaft.It is a magic pro with DJI props
The plastic plate the prop attaches to is likely damaged. You can easily replace that without replacing the whole motor.
Reactions: theDRONEranger
Found the kit on Amazon ... https://www.amazon.com/Mount-Installation-Mavic-Release-Propellers/dp/B0769GHW5S ... you'll need a Torx T6 screwdriver to remove the 3 screws and take the existing plate off.
Excellent suggestion. It's a hell of lot less expensive than replacing the possible broken parts and pieces. I was not aware Amazon sold those items. But then again, Amazon sells millions of items I don't know about. Good thing, too. I'd be tempted to stock up and then I 'd have to hope for a chance to use them to get my money's worth. I'll take the down down and search for repair/replacement parts instead of stocking up. Again, good suggestion.
Glad to be of help ... Crazy thing is that I live in the UK and can't buy those items off Amazon.com (they won't ship to the UK) ... But maybe that part number can come in handy.
bigbluesky
