LRF files
saltire
Sotland uk
So today the only files that will play when opening the sd card folder are the LRF files the mp4 just plays but is horrendous and breaks up .I switched the tab to MOV and its just the same .Tried a few sd cards but just the same even tried my other pc which was the same .Also tried the tele lens at 7x and its also plays the LRF files fine but not the MP4/Mov files .Am i missing something here ?
LRF files is low res copies of the high res video, almost anything will play them. The high res though... depending on resolution & frame rate usually require a powerful computer. Are your computer up to the task... have you tried to film in lower resolution like 1080P..? 4K+ can be demanding & if you on top of that turn up the fps it will make it even worse.
cbooth
