On several flights today, my descent was only about 1' every second or so.
I had been using DroneDeploy and figured it was an app issue.
Then, switched to DJI Go with the same results.
Happened in P, Sport and Tripod modes.
Just crazy slow at full stick down.
Weirdly, when the drone finally got to 10' or so, normal controls resumed.
So the first time it happened, I was full throttle down trying to land before battery died and when normal operations kicked in, I was flying full speed at ground and nearly crashed.
The next few flights, I was careful not to full stick down as I got close to ground.
I do see a message in the log "Downward altitude sensor data error."
Not sure that is related or not.
Any ideas what could be causing this erratic behavior?
